This command configures an incoming or outgoing policy filter for SA messages.
| peer all | Specifies all MSDP peers. |
| remoteaddr | Specifies the IP address of the MSDP peer. |
| in | Associates the SA filter with inbound SA messages. |
| out | Associates the SA filter with outbound SA messages. |
| filter-name | Specifies the name of the policy associated with an SA filter. To remove an SA filter, enter the none CLI keyword instead of filter-name. |
| vr_name | Specifies the name of the virtual router to which this command applies. If a name is not specified, it is extracted from the current CLI context. |
By default, no SA filter is configured for an MSDP peer. That is, incoming and outgoing SA messages are not filtered.
This command configures an SA filter such that only a specified set of SA messages are accepted or sent to a peer. Note that an SA filter does not adversely impact the flow of SA request and response messages.
The following example configures an incoming SA messages filter on an MSDP peer with the IP address 192.168.45.43:
configure msdp peer 192.168.45.43 sa-filter in allow_229
This command was first available in ExtremeXOS 12.0.
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the MSDP feature, see the Switch Engine v33.1.1 Licensing Guide document.
